RuudNL
I have to replace a 64 pin SMD chip with a thermal pad.
Since I am not very experienced in hot air soldering, I am afraid I will be overheating the chip while soldering the thermal pad under the chip.
Removing the old chip is not a problem, I cut all the pins and heat the chip until it comes lose. It is defective anyway!
Now, would it be a problem if I would use a thermal conducting compound under the chip, instead of soldering the thermal pad to the PCB?
Soldering the 64 pins by hand would not be a problem.
(The thermal pad is connected to ground, together with a couple of 'normal' pins of the chip.)
