Ok, after browsing I'm not sure I could find the answers to these questions..
background..
I got a ramsa wrt-820 off ebay for $152. runs great, I don't think I've found any major issues yet. There is some question to whether group 8 works right in the master section so I will tackle that last.
So I've taken one of the "modules" it's 4 channels at a time, and I've socketed the line input opamp, which is both the tape and the line opamp and the fader opamp. ( I left panning alone). It used 4560DD's and I have biased two 4450DD's into class a by shorting with a 10k resistor (I that does it? cross 1/2 and 6/7) and on channels 3 and 4 I have replaced line and the fader opamps with 5532's.
I then compare with two other 4560's channels and run a stereo program through them.
Here's the questions..
I run a 1k test tone through and make everybodies gane stage as close as possible before clipping with the meter on pre fader. (The knob position has changed for the 4560DD's in biased mode headroom loss?)
(Does it break the peak light? accuracy?)
5532 is about the same as the 4560's normal.
then I setup the fader's to match so that everything is equal outbound, everything is different there as well. 5532 being closes I beleive.
(run RR tests and the all the noise stats are similar.)
so now that all the "gain" stages are matched? (is that an acceptable way to do it?)
I listened...
5532 won very close to the 4560DD's with 10k resistors and then the normal channels where third, but not much difference at all, the 5532 was clearer and the bass had more solid punch.. It kind of made me think I was listening to a burbrown in comparison..
So, when I read the 5532 stats on power, Is it 4vs per side = 8vs and isn't the 4460DD the same, 4vs per side?
background..
I listened...
