bruno2000
I also use a cheap USB camera $20 on eBay. Works fine if you have a sturdy base. Not stereoscopic, but workable.
Bruno2000
Bruno2000
sodderboy said:You gotta figure the quantity needing removal. If it is above like, 200 or so then you can't afford to cheap out. Get the $150 Hakko tweezers instead of the $50. I like the tweezers with screw tips because I can make my own steel tips and screw them down.
But I am not doing hundreds of SMD caps.
I use these Ayoue tweezers plugged into a 701 hot air station.
You do not need a microscope unless you are doing SMD IC's. Then you cannot afford to blow it so you need quality. For the seldom work I do I use jewelers magnifiers. I have an old-school strap-on and also like these. I like the magnification to follow my gaze.
Just DOO it. On donor boards first. practice removal/replacement over and over.
Yup I use one of those class D chips in my tuner... not only are they tiny, but there is a heat sink pad on the bottom. so hot air is the only way to deal with them. I couldn't even bread board the design without laying out a dedicated PCB to test it.CJ said:maybe mask off the surrounding parts with heavy duty foil and use a simple heat gun to "hit and git" that part off the board,
they are using 3 watt smart phone chips in guitar amps now, 9 pin SMD the size of a pin head, you need a microscope and a special hot air machine, drop the part in the shag carpet and it is gone,![]()
Oh the BGA version even worse.yeah the VOX Mini, read the drama here if you want to feel better about your job,
http://www.badcaps.net/forum/showthread.php?t=20949
"Hi all,
Been grappling with this one for a while and no success so far.
These little guitar amps are rated at 3W and are quite nice, good sounding busking or bedroom amps.
I have a number of these with blown output chips and thought they would be quite a simple repair!!
On inspection I found that the chips were micro smd 9 ball WLCSP types. They are 1.2mm square and you need a microscope to see them.
TI makes a 2.5W TPA2010D1 that fits the bill... 9 pad BGATrouble is the type code bears no relevance to anything I can find. No IC manufacturers I've contacted so far have been able to identify the type number 'BP27'.
There are so many of these class D amp devices available with different specs and gains that it's impossible to guess which one would be the correct replacement.
I've tried the Vox forum with no joy either. Schematics are non existent too.
Pity it's not dodgy caps, easy stuff in comparison..."
