REQ: Mackie 1202 Original Schematics Please?
signup
Member
Hi, does anyone have a scanned in original pdf of the Mackie 1202 mixer?
Kind regards, Simon.
Thought I had one, but the pdf is damaged. I'll see if there's a chance of repairing it...
Ah! cheers, yes that would be fantastic, thank you :) if you cant repair, please send anyway and i can have a go at the repair too :)
thank you so much for the pdf! :) cant see the power supply on it though which is what i needed? I think one of the regulators has gone bad?
I do think it's a really simple, standard supply, utilizing the common L7815, L7915 regulators. Most likely culprits are the capacitors. Try replacing the smaller ones (22uf I think) first. Use normal (not low-ESR) ones.
Im getting over -16V out the 7915 reg - you are correct in the cap values :) 22uf wit two larger 2200uf caps too. i will swap them out as yes, sometimes hard to tell if they are failed unless tested as they dont always leak or bulge :) cheers :)
The 7815/7915 regulators are strapped with resistor dividers to raise voltage output to +/- 16V. How high does the -16V rail measure?
Those 22uF caps on the regulator outputs (C37/C38) should be at least 25V, not the 16V shown in the schematic.
In what way is the mixer operating improperly?
After glancing at the schemo, I see another "gotcha"....phantom resistors are only 0.25 Watt. Normally not an issue until a shorted mic cable is used. The power dissipation of the associated resistor(s) is over 0.33 Watts.
It's not just Mackie. I've seen it in many mixers/consoles....including Big Names. Not an issue, you say? Maybe not. But, I've seen more than a few "browned" resistors, especially in equipment that's been in service for awhile. For instance, in a studio, a dodgy cable can be left plugged in and sitting on the floor for weeks.
Bri
ah! that explains -16V so thats all ok! :)
High DB noise on the main outs without anything plugged in, so im guessing caps?
Cheers, Si.
Bri
good to know! thank you :) And I know the owner of the mixer uses phantom power too so i will have a look :)
