MusicWorks
Member
- Joined
- Jan 14, 2012
- Messages
- 10
Hi everyone!!
I am preparing a rack for these old German preamp modules by RFZ, model KV80/1 originally inside Mixer MP4084, I am having trouble following the old schematic, could someone help me out?:
This is the connector pinout:
You can check the full diagram for this preamp here http://www.lightandfilm.com/KV80.jpg
Please note it has TWO inputs (one balanced and one unbalanced) and THREE OUTPUTS (A1 goes connected to the second stage, A2 is the main LINE OUT and A3 is the prelisten line, or preamp direct out). As far as PSU requirements, it has two voltage lines +24V for the modules and +100V for the microphone power.
Tell me if this is correct (pin columns, from left to right)
PIN1 - Input 1 (grd)
PIN2 - Input 1 (+)
PIN3 - Input 1 (-)
PIN4 - Input 2 (grd)
PIN5 - Input 2 (+)
PIN6 - Light Signal Go/Return
PIN7 - GRD for A1, A3 and E3
PIN8 - A3, the lower pin I can't figure out
PiN9 - +100V
PIN10 - ?
PIN11 - A1 to E3 jumper (preamp stage to amp stage connection)
PIN12 - +24V
PIN13 - ?
PIN14 - LINE OUTPUT (A2)
PIN15 - To safety ground (0V)
I believe upper and lower pins are co-related, but I can't figure out certain pins. The one under A3 for instance and PIN columns 10 and 13. Any help would be much appreciated!!!
I will be posting pics of this project as soon as I get my order from Mouser with all the required PSU and connectors.
Come back soon for more pics!
PIN2 - Input 1 (+)
PIN3 - Input 1 (-)
PIN5 - Input 2 (+)
PiN9 - +100V
PIN10 - ?
PIN12 - +24V
PIN13 - ?
