RFZ V781 / AU 35 Output Transformer
These are DIN 41622 connectors/housing modules. You can get them at most German webshops like reichelt.com These are available in different sizes.
ps do you know where I can get robotron connector (stecker) with housing (gehause) like in the picture? I have the connector just not the housing gehause. It says it is TGL 10396
Hello,
these connectors are very old and the the metal inside is oxidized.
Use newer connectors. But you have a lot of cables to tame.
In my opinion that´s not a good way.
I developed the adapter exact for this application
You can get my adapter plate without the transformer. So you can use your transformers with little mechanic adaptions.
So you have fixed and propper connectors.
Best regards!
jokeramik
An addition: The advantage of using the original output transformers is that a very low output resistance is achieved in accordance with the specifications even when using these output transformers -> <40 Ohm. This makes it possible to connect up to two 600 Ohm loads (such as devices from Antonio de Maria Labs) without any significant loss of level. However, other standard output transformers with 600 Ohm:600 Ohm do not allow this. Here, a 50% voltage drop occurs just by connecting one device.
