Marik
[quote author="crazydoc"][quote author="xvlk"]
... and the ribbon itself {current path perpendicular to magnetic field}
voltage=B*l*velocity = B*l*diff(x,t)
where B is induction in the gap {you can measure it
by Hall probe from old videorecorder}
l is efffective length of the ribbon
diff(x,t) is ribbon velocity
This is one part of equations of the electrodynamic conversion.
[/quote]
So the faster the ribbon moves, the greater its output, (voltage or current, assuming a constant impedance and a constant displacement of the ribbon.) So intuitively (to me) this means that for electromagnetic portion of this system, output is proportional to frequency.
[/quote]
Crazydoc,
Your intuition is right!
The "v" (velocity of ribbon) identifies as (P1-P2)/zA, where P1-P2 is pressure difference, z-acoustic impedance of the ribbon, and A is ribbon area. If z is a mass reactance, then v=(P1*d/c*M*A)*cos0, where M=mass of the ribbon, and c=velocity of sound.
Because the ribbon workes as a mass controlled system, there is a natural fall with frequency increase.
[/quote]
[/quote]
Crazydoc,
So something must be damping this frequency dependent increased output, which I assume is a decreased displacement (excursion) of the ribbon as frequency increases, because of either the mass of the ribbon or the mass of air it has to displace.
