Good Morning everybody. I am working on revision boards of the units and still try to cure everything that I notice. I invented that small circuit to for the rectified side chain signal. Its super simple and uses a voltage divider R3 / R4 to change the ratio. It works super and as intend.
BUT - in the middle postions when R3 ≈ R4 a 50Hz noise in the audio signal increases by 6dB. (side note: its always R3 + R4 = 1Meg)
The Values of R1, R2, R3, and R4 are all changed by switches.
Does anyone has an idea on this?
Thank you,
Falk
