rock soderstrom
Tour de France
Hi folks
I have a defective Roland DEP5 on the workbench here. I love this old FX units, so I would like to repair it.
First diagnosis: the unit turns on, LED meter works, the display does nothing. The voltages at the designated test point all seem to be ok at first glance. The highest voltage 30V is with 37V above the tolerances (32V +/- 2V). This looks like the non-functioning display is not loading this rail and therefore the voltage is increased.
The 30V are for the driver ICs and are switched by a few "digital transistors" DTC114TS to the display.
The fluoresent display is a NEC FIP7CM6 for which I have no datasheet.
With further tests it turns out that the driver components 54563, especially IC14 become very hot, whether with attached display or without!
Further noticeable is the heat traces on the display backlighting, which does not work.
So far the first test, tonight I can probably continue.
My questions , does anyone know about this type fluorescent display? Maybe a data sheet available? Can I test the display without drivers to determine if the display basically works, or is defective, killing the drivers as well?
Service manual
Post in thread 'Roland' Roland
Service manual
