I already socketed burned one.
Another one installed and I swapped chips round but unfortunately it’s not working. :/
What is that RA2? What’s the purpose of it??
Most likely my display is done as it’s got a crack. I still don’t understand why I’m getting nearly 40v but it might be that display doesn’t take all the load it meant to.@Adrian55 i have the same problem with my dep5 , did you solve the problem ??
@Adrian55 I also replaced the Q12 BJT because it also reached a temperature of almost 90°, but this didn't help because the new one (an equivalent) heated up the same, and I also checked the original BJT with the transistor tester and in fact it wasn't damaged.
I am attaching the YouTube link of a video I made on my display while I was operating the rotary controls on the front panel of the multi effect
Yup I think too that display can be filled out as there is same two segments that don’t lit up. So maybe there is something that pulls them to ground all the time? Resistor array bad? Maybe controlling IC?I’ve posted on this already but this is what is happening with mine too and it’s not the display, well for me, as a working swap does same. I’m going to clear my current repair load then get back into this problem too
I did check traces from cpu controller as I did wonder if it was that. I don’t have sufficient logic kit, or probably knowledge, to take further if it is that surface mount ic. As to res networks…I have a feeling I checked or replaced those. What I didn’t do was replace some of the trannies mentioned here as couldnt source them. The digital ones I mean. I still wonder if it’s something fairly simple tho as the screen isn’t dead it’s just a few segments that aren’t being told to turn on. My screen swap proved that assumption and ruled out a fip display issue.Yup I think too that display can be filled out as there is same two segments that don’t lit up. So maybe there is something that pulls them to ground all the time? Resistor array bad? Maybe controlling IC?
Need to to look up schematic.
Unfortunately I’m no guru and not sure what the purpose of those two dtc ones is forYou mean them two next to display controllers?
