Bananahead
Member
Hello!
I have a R-880, rarely used (because ITB) but well loved. Last weekend I noticed a fairly strong and burned smell coming out of it. So, I shut it down, opened it up and saw almost every mica-cap looking "cracked". What's up with that?
I powered it up again and.....no smell. Damage already done...... Now it powers up, doesn't smell but input 2 is peaking. At least the LED is showing full input (but no sound/data is processed and sent to the outputs) I'm guessing some circuit feeding the AD either gave in or burned up, probably both.
I used my trusty nose sniffing the inside of the chassis and locating the smell originating from the front of the unit, where the converter chips (BB PCM54HP) are located. I could easily sniff up the strongest smell from the faulty area (the channel 2 input).
Can the mica caps be replaced just like that? After all it's the analog board, through hole mounted components and I'd gladly spend a few evenings recapping the thing. But reading abouth the mica caps they shouldn't fail, at least not 90% of the ~100 mica caps on the board, right? All the elyts are looking just fine, both on the board and the PSU. All channels get their +15-15 from the PSU
Any idea what happend with my R-880?
