hey folks. i have a re-201 here, which really is not running good and seems to have some wrong voltages compared to the shematics. first i measured like hell and now, after a few fixing attemps, i tracked it down to be already wrong when measuring on the rectifier after the transformer.
see here: http://www.omegav.ntnu.no/~karlto/space_echo/page12.png
after d13 and d16 i do not get any halfwaves on my scope just crazy messy pictures. i thought the only thing that it could be is the diodes itself, so i swapped them and the elko which is loaded afterwards. but it did not change anything. for the other wirings (red and grey) i can see the right rounded saw-function with 10ms for one period, which i assume is right.
on the wirings at the transormer i do messeaure:
grey wiring: 10VAC
yellow wiring: 14VAC
red wiring: 22,7VAC
here is the service manual: http://www.omegav.ntnu.no/~karlto/space_echo/serviceman.zip
the weird thing is, that also on the pin40 and pin39 i do get less voltages (approx. 2-3V less) than said in the shematics. even though the diodes and elkos are fine. also where it says 13V in the shematics (at d12) i only get approx. 10V which is really weird.
on the pin44 it's the same mess as after the diodes. here is a picture:
i ran out of ideas. this sucks, what could it be?
thanks a lot for helping.
grey wiring: 10VAC
red wiring: 22,7VAC
