The Spotty Fox said:
Hi
I've been looking to buy an Apex 460/Alctron T-11a or similar to mod within the UK but can't find any for sale.
Came across the Roxdon VT1 MKII vintage tube condenser mic - assembled in London and sold by 'micsdirect' (http://www.micsdirect.com/roxdon_vt1.htm)
Also sold on their website the iSK TM-66 which looks like it could be an ALctron T-11a re-brand.
http://www.micsdirect.com/isk_tm66.htm
Does anybody have one of these mics or know anything about them? There's nothing on recordinghacks to date and the company haven't released any specifications or response charts.
Any infomation or opinions would be useful
many thanks
SF
...I believe I answered your inquiry on GS a day or so ago, but I'll go into more detail here...the iSK and RoXdon mics are manufactured by Ningbo Shengke/TongXin (as previously mentioned)...they differ in design from the Alctron/Apex mic you're looking for, as they have simple single-stage, plate-follower circuits (the Apex/Alctron has a two-stage circuit)...I previously owned the iSK TM-66 (under a different brand) and it's quite good right out of the box, even better with a proper tube swap...mods designed to be used on a HST-11A will not apply to these single-stage tube mics...
...Alctron is actually a sales rep for a number of manufacturing sources in China, so there's not much continuity in their selection as they offer mics from both the Shengke/TongXin facilities and the competing ShuaiYin factory, which actually makes the Apex and Nady mics...
...as Krumlee suggested, I had recommended in my GS post that you contact Lifelong in the UK to see if they can source the HST-11A for you...
...as far as the Thomann SCT800, which I believed originated years ago from sE Electronics, but now is coming from another source, it is a cardioid-only design with a single circuit board, unlike the HST-11A's two PC boards...from the recordinghack.com's website:
"Unlike the Apex 460, the SCT 800 uses a single circuit board. It is a dual-layer board, likely with through-hole plating, which makes desoldering components (for modification) somewhat more difficult."
...mics that would allow the Apex 460 mods would be the Alctron HST-11A, the Nady TCM-1150, and the Carvin CTM-100...
...and then there's this:
http://www.ebay.com/itm/BadAax-T-11A-Vacuum-Tube-Condenser-Microphone-/371037763023
...there are pre-modded versions of this mic also available, that have had some or all of the major components already upgraded...the Avantone CV-12 ($499) is the least upgraded, while the Stellar CM-5 ($415) and the Advanced Audio CM12 ($695) both have all the major upgrades...the Stellar CM-5 is the best option at only $415 US (upgraded/modded circuit, upgraded C12-type capsule, upgraded T14-type transformer, and premium 6072A tube)...
