Jakob,
Did you do any tests to find if this is noticably better than grounding the heater only at the PSU instead? I have tried both but I had figured with the 'mogami' type cable it would be better to use the two dedicated heater strands to bring the current back to the PSU. Earthing is always a tricky subject and I fear that I may have a misconception!
Tim,
My PCB is probably not as well thought out as might be and is not a true star ground. If you're cunning you can make the screw that holds the PCB in place act as the grounding.
When I used this I actually ran wires directly from the XLR to the tube for the heaters.
Have you made the PCB yet? If nt then hold on and I'll have a look this weekend and see if there is any more trouble shooting to be done.
ta!
Tim,
ta!
