No, the circuit is pushpull, the two currents cancel each other regarding the resulting magnetization. No gap necessaryI don't know about your Hammond but the output transformer must be gapped because it feeds the output tubes DC power supply.
You are right ! My badNo, the circuit is pushpull, the two currents cancel each other regarding the resulting magnetization. No gap necessary
That definitely won't handle the power level cleanly and I doubt it handles the current, DC resistance is high meaning small gauge wire.Hammond 850LA should work well
Have not used it but the UTM3580 is listed on their site for 436/ 124 style builds
Did you take any measurements ? Would be good to know the performance in a real use scenario, I have been meaning to try these for a while but the price just sounded too good to be true.I don't recommend it. Tried it in a very similar 6CG7 push pull output stage and got the characteristic lack of low end of an underspec'd transformer. I also ordered their gapped BA2 output transformer which wasn't great in the stock RCA circuit it's advertised for either.
You mean the secondary resistance ?That definitely won't handle the power level cleanly and I doubt it handles the current, DC resistance is high meaning small gauge wire.
Last order I placed was very quick to arrive, just a few weeks. Maybe they have managed to build up some stock ?I initially built my pair with edcor o/p transformers that i had lying around. They worked but I think were slightly underspecced. I eventually used a pair of sowter outs that are great but not so easy to get now that Carnhill have taken them over. I think I was waiting at least 3 or 4 months for them to be delivered from first placing the order. I'm not even sure they still make them. A real shame the day Brian sold the company.
Not sure, but the catalogue indicates that it physically weights twice as much (1/2 lb compared to 1/4lb) even without any shielding (which the J series have). Metal mass counts for something?Is the X series rated higher max level than the J series?
If you look at their website it gives a list of the transformers that they prioritise making and the 436 output is not on it. Also they say their is a 90 day lead time.Last order I placed was very quick to arrive, just a few weeks. Maybe they have managed to build up some stock ?
Sowter 8650 should work too ? I believe it's used in the Thermionic Culture Phoenix that's also a Altec 436 type circuit with a 12AU7 type output tube.
I have ordered 3x products that were not on the list and to my surprise they all came quickly.If you look at their website it gives a list of the transformers that they prioritise making and the 436 output is not on it. Also they say their is a 90 day lead time.
The 12au7 is a different valve to a 6cg7 therefore the 8650 may not be optimal with a 6cg7.
Which Edcor did you find was underspecced?I initially built my pair with edcor o/p transformers that i had lying around. They worked but I think were slightly underspecced. I eventually used a pair of sowter outs that are great but not so easy to get now that Carnhill have taken them over. I think I was waiting at least 3 or 4 months for them to be delivered from first placing the order. I'm not even sure they still make them. A real shame the day Brian sold the company.
