Ricardus
WILL SOLDER FOR FOOD
Who here can give me the best explanation about when when you downsample from 96k to 44.1K (96 not being an even multiple of 44.1), why there are no audible artifacts?
But a modern converter does just that on the inside: Oversampling (upsampling -> filtering ->downsampling). A legacy converter using analog filtering only would be a different matter, but it will be less transparent in terms of phase shift and frequency response.In the end the best sample rate conversion is often a D/A/D trip through another converter.
This guy is claiming he could hear 'metallic grinding noises' in the examples he heard.It's subjective whether artifacts are audible or not.
Someone I know is hung up on the whole 96 not being an even multiple of 44.1 thing, and says " Mix two frequencies you get side bands...
I told him that he was either working near an auto body shop with the windows open, or something was very wrong because I've resampled 1000 things over the years and haven't heard metal grinding.
In a double blind test, if you can't identify which is which, then you can't hear it.
My guess is he knew which was which when he was listening, and like in all of these "audiophile" listening tests, his brain just lied to him to confirm his bias.
RE the side bands not happening in sample rate conversion. Could you expand on that a bit? Something I could present him with to help him understand better?Yeah - you do. But that is not what is happening in sample rate conversion.
As the saying goes..."A little knowledge is a dangerous thing"
Thank you! That contribution was SUPER helpful.I guess you could approach that two ways.
The first would be that there are no artifacts for the same reason there are (usually) no audible artifacts when you sample analog audio at 44.1k, because the system properly bandlimits the input to below the Nyquist criterion before generating the output samples.
The second would be to follow up on the implicit assumption about downsampling by 2 being mathematically simpler. It is, but I suspect the questioner doesn't really understand the math involved, so leaps to the conclusion that difficult math must mean errors large enough to hear. With modern processors the only limit to all artifacts being more than 140dB below full scale is if you need super low latency or need to restrict memory usage for some reason.
Have you (or the originator of the question) seen the SRC comparison page?
SRC comparison
The sweep charts can be a little confusing to read the first time you see them. The default chart uses a sine wave sweep with frequency increasing bottom to top, and amplitude indicated by color. The input signal is the bright yellow curve up the middle, and any aliasing shows up as darker colors. You can also choose from a drop down menu 1kHz single frequency tone at low and high amplitude, frequency response, phase response, and view the impulse response. It looks like the default converters shown right now are essentially faultless, so it is instructive to change one of the views to an older lesser quality converter, or a converter that has to work at low latency in real time to see what artifacts look like in the sweep chart or the 1kHz.
So he(?) must have some exposure to signal processing terminology, since mixing in the audio terminology sense obviously does not produce sidebands. Mixing in the RF sense would probably be thought of as multiplication by a lay person (as opposed to the addition you would get with an audio mixer).
I guess you could ask why he thinks that SRC involves a mixing operation, although that might go down a rabbit trail of sampling as convolution that you don't really want to get in to.
Really, that SRC comparison page, or doing the equivalent yourself, should be enough to settle it. Maybe just start there, suggest he make some test tones at 96k and convert them to 44.1k himself, and look at an FFT of the result. There are some caveats around setting up the FFT properly, but it should be obvious that you don't get sidebands with a decent quality SRC.
As an aside / anecdote: I used to work in Digital TV (the algorithm design and implementation). Tests showed viewers noting improved picture quality when the picture quality remained the same but the sound was improved. Our senses are massively subjective and also subliminally synaesthetic.
By far the best SRC IMO is finalcd, a freeware comand line program using 1.5 million taps:
