mulletchuck
got both boards all stuffed, that red resistor is nowhere to be found. gonna order one :\
but anything between 1K5 and 2K5, 1W will be fine, it's merely a current limiting resistor for the meter backlight.
horvitz said:Hey, no worries on sending me the resistor. Save yourself the time and the postage, I've got something suitable here.
Chuck, you'll burn out the 1/4W if you use it so don't bother trying.
Wow that was fast man!mulletchuck said:NO SMOKE!!!!!!
Woohooo!!!!!!!
therecordingart said:Everything is stuffed except the TRS and the missing 1 watt resistor. I'm waiting for that final piece before finishing. I've gotta say that I'm worried about this thing firing up right away because I spent so much time working on it.
How critical is the value of the 1 watt 1k5 resistor? I'm sure I can find some equal valued half watters to parallel that would get me in the area of the 1k5, but not exact.
ruckus328 said:therecordingart said:Everything is stuffed except the TRS and the missing 1 watt resistor. I'm waiting for that final piece before finishing. I've gotta say that I'm worried about this thing firing up right away because I spent so much time working on it.
Mentioned it a little while back but it probably got burried. This 1W 1K5 resistor is a current limiting resistor for the Meter backlight. Its value is not critical at all, though you don't want to go any lower than 1K5. Wattage is critical though as it's dropping alot of volts, burning approx 5/8W. Reasonable value is anything between 1K5 and 2K5. If you have two 1/2W 1K resistors or something close, that would work just fine.
