Schematics and knowledge sharing thoughts
Good points! I totally get companies wanting to QC their own repairs. Mostly concerned with the ones that have no service centers, and wont share schemos. I would sign an NDA, might be worth emailing a few companies about that. Haven't been offered that solution but I can inquire!
Totally agree most things are easy to get around in a block diagram sort of way. I don't have an issue repairing or figuring out circuits, just prefer having a schematic reference. I have run across errors in schematics for sure! nice to have the unit and schemo to compare!
I understand. But to be blunt, in this day and age there are more companies who copy schematics and put it out as products then companies doing original design. In fact some of our early group diy work was used by a few companies. It wasn’t supposed to be that way. But it happened. So I see why companies hesitate. To me an NDA really shows a you are serious about protecting their stuff and just fixing your stuff. I have a few with different companies for that reason.😎
I've watched significant changes in the audio markets over several decades.
What does it take to be a success (hint more than just a serviceable sku design)?
Ripping off other peoples designs is mostly short term thinking but I have seen some succeed at it.
I have experienced this exact thing... no longer do warranty work for companies, which is mostly test, make sure its deffective, and send them a new unit... or at best, board swapping..
Yes I can attest to that. My last stint the big thing was board swaps for field guys unless it was something super simple. Then the boards came back to the mothership for rework and back into the cycle of use for swaps. While this does expedite things, it really isn't a healthy option IMHO. The better option is field board repair if and when possible as it is the fastest way to resolve things.
Yes, but if you're sold on that old thing and you love it so much you can't live without it, then the manufacturer faces a choice between selling you a "new one" of the latest-greatest flavour (typically over 50% margin) or selling a spare module (a single PCB can easily be as much as 95% margin) ..... or making no money at all because, armed with the circuit diagram, you managed to repair it yourself or paid an independent repair house but either way, no revenue flows to the OEM. There's arguments for both sides, as an engineer I know ANYTHING can be fixed and having worked for equipment manufacturers for 40+ of years, I can tell you that'll be their (cynical) Policies. There are a couple of other reasons, mainly around (perceived) liabilities but the revenue one's the lynch pin.
I think it is important to distinguish between professional and consumer/semipro suppliers. The professional ones know their customers will want their gear to be earning as much as possible all the time and they cannot afford the time or effort to deal with sending items off for repair. It needs to be fixed now and that is why they have an on site service department who will make repairs. For this reason they provide full service info. For consumer/semipro, little if any of the above applies.
ian
Lexicon and Eventide published schemos. While some/many failures on their products can be traced to analog I/O or PSU problems, good luck doing anything on the digital sections without service info.
Bri
Trying to repair a friend’s Eventide H910 was the most humbling thing I’ve attempted to fix. It took me less than an hour to figure out that the PSU voltages were all bonkers because the power transformer was wired for 220v, instead of 110. I corrected that and changed one of the regulators, then the power was normal, so I had high hopes that I got off easy. Nope. I pulled every one of the million tantalum caps to test them, poked around for a few days after that, and eventually gave up.
What does (or doesn't) it do?
Bri
Bri
It’s been a few years so I’m a bit fuzzy on what exactly it didn’t do, but I don’t think it had any effect at all and do remember that I had signal getting up to the digital section, and could inject signal into the exit and had signal on the output. In the digital section I did all the standard stuff like checking all the power pins on the chips, testing caps, feeling for an abnormally hot chip, testing for shorts, etc., but even with having the schematics I honestly don’t have enough knowledge to troubleshoot the digital circuit.
ian
I don't work with consumer grade or semi-pro manufacturers... When an end-user demands high system availability and or short MTTRs, then the response is to sell on-site spares holding to them (conveniently increasing the manufacturer's revenue). Faulty modules/units can then be managed as above, i.e. repairs are effected by the OEM using a return-to-base model.
A lot of valid reasons where written here but there was one very important reason for some companies not releasing Schematics that was not Brought up.
Honest truth in the XXI century:
Companies don't you to repair their products,
Companies don't want the product you bought from them to be repaired
Companies want you to ditch the failed product and buy from them a new one, or the new model, or version MKII
Companies don't do and don't want to do any longer products that are made to last a lifetime
The market and economics are completely based in planned obsolescence,
and actually a lot of failures of products were tested, or some parts of the circuit were designed with less quality companies so that they fail in a few years.
Releasing the Schematics would make it easier for consumers to find they designed a product to fail, would make it easy to repair it and to share how to solve the weak points, and if all that happens they would not sell you a new unit
Planned Obsolescence is not a conspiracy theory it's very real and implemented in the majority of electronic products at the present.
"Planned obsolescence describes the practice of designing products to break quickly or become obsolete in the short to mid-term. The general idea behind this is to encourage sales of new products and upgrades"
But why would you buy a new product from the same company whose previous product failed before it should have ?
If it fails during DLP, then it's repaired (or probably replaced) under warranty. From the manufacturer's point of view, failures beyond DLP are "acceptable", or perhaps intentional. Makers also monitor the incidence of warranty claims and use that data to tweak designs and or adjust their future warranty durations.
It's not exactly new science; Brunel was making pithy comments about it in the 19th Century!
