Schoeps CMN 51 Powersupply
geebeeVIE
Member
Hi All,
I have been offered a Schoeps CMV51/9 with CM51/U capsule.
Unfortunately there are neither Powersupply or Cable included, but the price seems good and cosmetically the mic looks good.
On the web there is very little information to be found.
I think it uses a 6AU6 Tube, so it would need 6,3V heater and some 120-145V (?) Plate Voltage.
Any ideas for a power supply circuit? Could any of the "standard powersupplies" that are available on the forum be used?
Look for Telefunken schematics.
If there wasn't exact model with tele logo you will find something similar.
From what i remember most 6au6 schoeps used negative voltage.
Here's some handrawed schematic from the net.
https://www.flickr.com/photos/audiotesla/8589355756
If you will look for schoeps/telefunken/siemens schematics with 6au6 you will find many similarities.
These might help:
http://www.xaudia.com/xaudia/Schematics/Pages/Schoeps.html#0
Schoeps N60B fits for that one, I do not know if CM51 is any similar.
I also have the schematics, but cannot convert it right now to fit here.
If we are on Stewart page, here's another example:
http://www.xaudia.com/xaudia/Schematics/Pages/ELAM_files/Media/ElaM_200_201/ElaM_200_201.jpg?disposition=download
http://www.xaudia.com/xaudia/Schematics/Pages/ELAM_files/Media/ElaM_PSUi/ElaM_PSUi.jpg?disposition=download
I finally was able to compare the hand-drawn schematics with the CV60 schema. They are the same except the carbon pieces. I was not able to read or understand the text(Dutch?) though. CV60 was mentioned there too. The PSU schema has an obvious mistake: C1,C2,C3 are polarity reversed.  By the way, what is the reason for using negative voltage? Would it not work as well with positive?
