Seeking Advice: AKG P820 Microphone without Power Supply Unit
mateo22
Member
Vienna
Hello everyone,
I find myself in a bit of a situation as I recently acquired an AKG P820 microphone without the accompanying power supply unit.
I'm seeking advice on how to proceed in this situation. Are there any alternative power supply units I could consider using with the AKG P820 microphone? Or perhaps recommendations on where I might find a compatible power supply unit I could potentially modify for this purpose?
Additionally, I would greatly appreciate it if someone could provide me with the schematic for the AKG P820 microphone and its power supply unit, if available.
Thank you for your time and assistance!
Best regards,
Mateo
  • AKG_P820_Service_Documentation.pdf
    198.2 KB
Hello everyone,
Best regards,
Mateo
Yes, I did that a year ago, you have to modify a 7-pin cable.. and if you want the pad, solder a switch. Any Aphex 460 power supply works... I used the Tbone SCT 2000 power supply. I'll check tomorrow to see if I can still find the cable modification I measured
Dear commanderberti and michi_fuchs, thank you immensely for sharing the schematic and tips to modify the power supply unit for my AKG P820 microphone. Your help is greatly appreciated!
Best, Mateo
Very interesting that the pad is achieved by also totally throwing off the tube bias :oops:
Thanks for your input, Khron! I'm still in the process of understanding all the details. Do you have any suggestions on the best way to integrate a pad switch into the schematic while considering the tube bias? I've uploaded a photo of the SCT2000 PSU insights and the schematic from the Apex 460. I recall reading somewhere in the forum that the Apex 460 PSU isn't an exact match for the T-Bone SCT 2000. Unfortunately, I couldn't find the schematic for the T-Bone SCT 2000. Any thoughts or comparisons would be greatly appreciated!
    1.3 MB
    63.5 KB
you only have 2 switch Pins 4-5 .. for the pad, see my schematic..
Heyy 👋 I have the same problem.. I have no power supply unit for my akg p820 because the transformer inside is broke... But I don't understand the modification part when I purchase another power supply unit. Could someone explain it or send me a link to a video please 🙏
hallo Can, könntest Du inzwischen eine Lösung finden, ich bin erst jetzt leider wieder dabei? Beste Grüße Mateo
