Seeking Advice: Best Preamp Design for Low-Noise, Balanced Microphones
Either the THAT or TI solutions would give you what you want with suitable Arduino control juju.
PGA2500 and the THAT solutions are SOTA for mike preamp performance (if you exclude some Earthworks designs under special circumstances)
PGA2505 isn't quite as good as PGA2500 & the THATs but the difference is moot for most people.
I wouldn't let the low voltage output of the TI devices put you off. VERY good soundcards have been made with PGA2500. If you want +20dBu output, use the THATs or have a 10dB gain OPA on +/- 15V rails after the PGA2500
The NJM chip is a Volume Control. Not suitable for Preamp GAIN which is what you want for SOTA performance.
If you use PGA2500, there are a few tricks from the THAT datasheets that improve performance and, more importantly, long term reliability.
Myself and several others don't see any value in keeping the NJM chip, it doesn't provide any useful control over gain.
+1 110%
Although they may seem similar in some respects, a variable-gain preamplifier is not at all the same thing as a fixed-gain preamp followed by a volume control. The former is used to match levels from a mic of unknown sensitivity exposed to an acoustic source of unknown SPL to a device of known sensitivity (console, recorder, etc.). The latter, which is what you've got with the NJM part, is just not suitable as an input signal conditioner.
Consider the case where the mic and source conspire to make a signal that just barely puts the SSM2019 into clipping. Ideally, you'd like to back off the gain slightly to avoid the clipping. But short of turning on the pad, there is no way for your topology to do that. The NJM will attenuate the clipped signal, but the signal will remain clipped at your console/recorder. If you have a source that clips the 2019 when the pad is on, there is no way for your design to correctly handle it.
This is why it is absolutely necessary to vary the 2019's gain to match the source. You can use a THAT5171, a motorized pot, or a bank of relay-switched resistors. Whatever method you choose, the gain set resistance needs to be absolutely voltage-linear, have low self-noise, and be isolated from any interfering signals.
Besides, the NJM has other liabilities, like limited voltage headroom and high sensitivity to noise on its control pin. It is a "lo-fi" part that will just degrade a your SSM2019's performance.
