Musika - thank you for those additional pages for the 1100 Series. Oddly, they don't contain an option selection matrix that generates an actual part number the way the modern datasheets do. Hmmm...Penny & Giles 1100 Series:
Could it be the letters designate resistance, or the presence of a mute switch, or something else? I’ve been asking about this for years to no avail.
Yes, those 3000 Series pages are examples of the modern datasheets. Each fader option has an associated key number. Choosing the various options is how you build up a final part number. I don't see anything similar in the older datasheets.Jeffbro,
I just found these for the 3000 series faders - is this type of page what you are looking for? Unfortunately, I am not sure if I have the other P&G series fader pages.
I may have found it here:
Curtis Wright
Measure the space between the fader mounting holes and let me know. Also, If you need a stereo master fader, 99% of them are all 100mm, so any of us console makers can provide a fader panel. I seem to remember them being 5K?I'm currently trying to find a replacement for a 104mm stereo master fader in a GML automation system. Sadly, GML disavows all knowledge of their old automation systems. Since the automation has not been used in 20 years my plan is to install a regular non-vca fader. The only technical literature I can find is for the 3000 Series, but there are lots of faders out there from different, older series like the 1000 Series. My problem is that I need to determine if mounting holes and overall physical sizes are compatible with the fader I need to replace.
Can anyone point me to a source of P&G technical information for older faders?
Yes, 5k stereo.Measure the space between the fader mounting holes and let me know. Also, If you need a stereo master fader, 99% of them are all 100mm, so any of us console makers can provide a fader panel. I seem to remember them being 5K?
Are you sure that's the correct number? If you look at the PGF8000 Series information on the CW website you'll see that the 2nd part number digit codes for the stroke length and the 8000 series only comes wt 100mm stroke. That is coded with a 1 so all 8000 Series numbers must take the form PGF81xx.Hello! I am looking for a GML Stereofader 8403. Hope someone can help me!
Sorry for the late reply, I missed the new message notification. Here are some photos:
The dodgy fader is still in service, with a bit of tape to hold the knob shaft pressed sideways into a position where both channels pass audio! When I install the replacement standard fader next week I'll do a more thorough repair to the GML so that it will be available in the future as a backup.Well, automation is a bit of a stretch. I only use the faders to move to and save certain positions, which I can call up via presets. I built the electronics myself for my Focusrite project. What happened to your broken fader, do you still have it?
