Send 'N Blend Support Thread
Someone with some pcb-making skills should whip up a small SnB like board for easy implementation into other projects that could benefit from it. Sort of odd that there are no purchaseable/printable pcb projects other than this, considering the myriad of other small utility boards available from both resellers and open sourced. I'd get a bunch ✌️
https://ka-electronics.com/shop/index.php?route=product/product&product_id=125
Thanks y'all.
It can be used as 2 mono channels by using separate pots though the Add/Mix function will control both channels unless the relays are split.
I also see it as a two input stereo mixer, buffer, gain make-up stage etc.
Question for anybody who has built this: does the volume stay constant when blending or is there a boost when the pot is in the middle? (when used with a compressor for example, so phase coherent signals)
