ruckus328
Dazazone said:2 kits, payment sent. hope I'm not too late for the front panels
Nope, not at all. You're good.
A big thanks to everyone that has supported this project!
I've been getting alot of inquires as far as available BOM, what else is needed, what's in the kits, transformer needed, calibration, assembly instructions, etc.
Just so everyone is clear:
I am working on assembly and calibration instructions. Assembly is as straightfroward and easy as it gets and will be fully documented. It will be available far in advanced before anyone receives the boards.
Calibration is very easy and can be done with your soundcard & RMAA (free). If you have a true RMS meter, calibration is even easier but it is not required at all. Calibration process takes about 30 minutes.
I am going through the BOM and triple checking for correctness, it will be posted later this week. However Ptownkid will be providing component kits for the unit at an amazing price. It includes everything to build the pcb's, the ribbon cable, connectors, AS WELL as nearly everything you need for the front and rear panel (pushbuttons, toggle switches, LED, power switch, bargraph, xlr's, etc etc.)
The only things not included in the kit that you need to build an entire unit:
-The boards and (Optional) front panel, which are purchased through me
-Case (Can be purchased from parmetal or modushop)
-Power Transformer (Farnell, mouser, digikey, newark, etc)
-IEC Connector and fuse (Farnell, mouser, digikey, newark, etc)
-Knobs (Farnell, mouser, digikey, newark, etc)
-Wire (Farnell, mouser, digikey, newark, etc)
-Meter (Any meter can by used but my front panel is designed for the Sifam AL19 style) (AL19 clone meters can also be purchased by Ptownkid)
-Hardware of your choice for mounting boards, the star ground, etc. (Farnell, mouser, digikey, newark, any hardware store, etc) - Board holes are sized for M4 or 6-32 screws with plenty of clearance for washers, standoffs, etc.
That is absolutely everything you would need to build an entire unit. I will provide support & recommendations for these items if anyone needs help on what to select.
If anyone has any other questions, please don't hesitate to ask.
