Serpent Audio Send ‘N Blend Mix Controller PCB wanted
znjamznjam
Hy
Please have anybody PCB for Serpent Audio Send ‘N Blend Mix Controller?
If you have gerber file is also ok.
Serpent audio not react if i ask for pcb
thanks in advance
Came here to say the same thing.  The info from the first post in that thread is also duplicated here: https://www.livingnote.com/diy/linear/crushnblend
(never hurts to have it in more than one place!)
Thank you but i will for line level 2x mono balanced wet/dry solution for kick and bass parallel compression.
Send'N Blend is is nice solution and also balanced.
There are not so many solutions for this.
Maybe balance line level direct in and out with bussen per channel option. I have not find schematic fot that solution.
White i need is hardware solution for Parallel compression (DBX 160 hardware)between DAW and summing device without need to by extra mixer.
Thanks in advance
