[quote author="seavote"]hi, im planning on building a copy of the sennheiser mkh30 a few projects from now.but im learning more about these circuits in the meantime. i had heard that these mics should be well sheilded. [/quote]
I agree with coleagues, that building of copy of MKH30 is full of
troubles. It is Hibbing s RF circuit.
Its princip is combination of phase detector {griese mic} and
two tuned circuit mic {early Schoeps} It is hard to understand
because all lies in construction of RF transformer which are rather coupled circuits than pure transformer. Make analysis of schemo which I had send here some month ago...
Only way to understand is to DIY both - Griese and Schoeps.
Then crosses it.
Try to make copy of van der Ziel s mic with modern devices.
Much more simpler to understand than Hibbing s and without secrets.
Yes, shielding. RF circuit in all RF microphones is parametric amplifier.
In all parametric amps, external RF field varies core permeability - it adds with capsule changes and causes hum. Hibbings circuit is symetric. Then some amount of noise {if it is in homogenous field} is cancelled. It is kind of astatised parametric amp. Then MKH30 {and also van der Ziel s} is much less susceptible to LF magnetic field than Griese design { i.e. MKH405.} But one layer of permalloy foil inside mic body may work.
And use very quality RF coils. Caps from siemens K1 works well.
Caps have small leak, you can not shield it {by the way, I can not imagine, how {and why} to shield cap core inside mic.
And you must have Q-meter, oscilloscope and RF generator to
make serious work. To DIY high - Q coil is sometime veird.
And have patiency. It is years of work to develop good parametric
amplifier {or RF mic}
Good luck,
xvlk
