the frontpanel layout is not even beta, Rowan, there is already a kind of contribution to your splendid work, but I´m still thinking about a solution. The switches are from a groupbuy, they are some kind of chinsese Elma substitutes. I don´t know the brand. For the meters I can´t say for now, if they will work or not. I´ll test them.
regards
Bernd
I also bought some at the groupbuy at frank's forum but i also bought some of the same switches at the finish webshope uraltone.
http://www.uraltone.com/
[quote author="bernbrue"]The switches are from Emres groupbuy at Franks Forum. Here is a datasheet.
http://www.fk-industrie.de/downloads/srcl370s.pdf
regards
Bernd[/quote]
Ok. Have you used these before? Are they OK?
The datasheet doesn't say if it's shorting or non-shorting? I've seen the ones at Uraltone, they are non-shorting. I would need some switches for some other projects as well.
[quote author="analag"]Is that Fairchild I see on the front panel? I am in awe.
analag[/quote]
I am not sure If I undersand you right, but If you would not like to have all those Compressors labled with Fairchild on it, it would maybe a good idea to give a clear name you desire to this community.
regards
Bernd[/quote]
product link http://www.fk-industrie.de/de/produktkatalog/S/R/321.html
they are 2 deck, 23 position, shorting switches with end stop. They are also available in various other configuration. I won´t do a groupbuy for these switches since I´m quite busy with prototyping. Later I will do a groupbuy for a costum made power transformer for this project (Europeans only). I think, there will be a groupbuy for US members as well.
regards
Bernd
I guess this question should go to Silent Arts. Is it possible that the 2 left-side tubes are so close to the 2 10uf Wima caps that they will heat the caps unnecessarily? These mu designs always idle hot. I always thought a watchdog circuit that put the tubes at a higher bias after 5 mins of no audio would be cool.
Probably make the tubes last 3x longer too.
