it can important that there is a cap (or better still an LC) to shunt common mode noise on the analog 0V to the input neutral.
We needed a 5V rail on one box and derived it from a higher (18V) one thru a little switchy regulator bit. Really user friendly. OUR circuit liked it fine. One part. (plus a filter cap.) And a post regulator...with it's bits...but I digress... 5V 1A max. Nothing, right?
The 100s of kHz backfeed...multiple, multiple, frequencies...back thru the 18V winding, back thru the primaries (of the linear transformer,) back out the connector, all the way back down the power line. Violated FCC 'conducted' requirements. Straight thru that giant toroid plus caps. We had no broadcast license for those frequencies, basically.
The compliance testing lab guy says "oh yeah, a couple caps (L+N) to ground will clear that right up" ...which they did. Kinda pricey big ole film caps, but whatever. I don't mind film caps. 'Self healing' and all that jazz.
Then we threw it on a GFI receptacle. You know, just to see...
It turned out smaller filter caps got us FCC cert too. And if we made them small enough, you can even use it on a GFI receptacle. It's still bullshit doing it like that tho. What's wrong with maybe just not broadcasting in the first place? IDK. Seems a lot simpler to me. Plus / minus the big film caps.
I kinda gotta wonder too. How many SMPS enthusiasts advocating on here are concerned, or even _aware_ about complying with regulatory agency emissions requirements? This is a question of target audience then. If you want to build _one,_ the FCC probably ain't pulling up with the cat detector van to razz you about it. 'More than one,' maybe different story. But I'm still following here. Meanwell LED supplies, capaciatnce multipliers, desks that run electric bills up. Things change. We'll see.
Plus there's this guy too though:
https://groupdiy.com/threads/51xaudio-by-silent-arts.39570/
He seems to have went linear. Kinda maybe might know a bit about this particular subject too... perhaps? IDK.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
