Hard to say, but one of the possibilities is that it's a multi-output smps with a single switcher. In this configuration, the PS is stable as long as the total load of the rails exceeds a minimum.Another thought: I also have planned to buy a Midas L6 lunchbox. It is a 6 space lunchbox. In theory it should work with only one module loaded...or also this boxes need a minimal load?
All this is 100% subjective. I can hardly accept it as "evidence".Here's some anecdotal evidence.
Then there is something wrong with the smps or the way it is implemented in the unit. have you checked the voltage, and how clean it is?For my Daking FET II comps, one came with an APS 48V 0.25A linear supply and the other with a Meanwell 48V 0.5A Switcher. Switching between the two supplies on the same unit, there is a distinct difference.
It's always a risky concept to put figures on something that cannot be measured. There are no units for punch, bigness, thinness, anemy.The linear supply is punchier and bigger and the switcher thinner and more anemic and I strongly preferred the linear supply. I'd say the improvement is about 20% and worth it to me to find another linear supply.
The nature of phantom power that is supplied common mode to the microphones provides a degree of rejection.The supplies I mentioned are both external "brick" supplies with one being a Advanced Power Systems (good quality) class 2 transformer / linear type and the other a Meanwell smps. The meanwell smps is what Daking supplied as a replacement for what I imagine was the original class 2 linear supply that went bad or was lost, so the meanwell is newer and the APS older. They both put out the correct voltage but I have not measured for noise. There is no undue noise in the audio listening-wise so there's no obvious indications that the SMPS is bad. The linear supply simply sounds a bit better than the SMPS when powering the same unit. I have no skin in this game, it's just what my ears tell me consistently. It led me to contact Daking aas I wanted to find another advanced power systems supply to better match the unit, but they are not made anymore unfortunately.
I find it very surprizing that Daking put on the market the smps version without properly evaluating it.It led me to contact Daking aas I wanted to find another advanced power systems supply to better match the unit, but they are not made anymore unfortunately.
Just to be clear, this is the power supply for their FET II compressor. There's no phantom power involved here. I thought it was relevant because the sonic merits of linear vs switchers in regard to phantom power was being discussed so that was extrapolated to non phantom audio circuits. For the sake of relevance, my modified rolls phantom hex sounds better than the phantom given by my 500 series chassis. Go figure. I'm not trying to convince anyone here that I'm right. It's more for those that are interested in optimizing the sonic performance of their gear so they can try things for themselves and decide what's best for their ears. In my case, I wish the meanwell would sound as good or better because it is smaller and much lighter, but unfortunately it doesn't. When I have the time, I'll post some clips and you can decide for yourselves.I find it very surprizing that Daking put on the market the smps version without properly evaluating it.
What is their current implement of phantom PS?
Then, if it's corroborated by DBLT,there is something wrong with the phantom PSU in your 500 chassis.For the sake of relevance, my modified rolls phantom hex sounds better than the phantom given by my 500 series chassis.
If you can’t measure it, it’s probably not your ears that are hearing it.
hard to measure "punchier and bigger" vs "thinner and more anemic" with test equipment
Well, it seems you're using a prerecorded signal, so why don't you do a mult and then a null test?Ok. Here's the samples. Everything the exact same except I switched power supplies. Gave each run 5 minutes warm up time before recording. They sound different to me!
You can't do a proper null test if you recorded your samples in different time. You need to record simultaneously and use the same converter.I just did a null test and there's an audible difference above the noise floor.
