Shure 849 microphone
LevinGuitar
The owner's manual is the same for the 849, SM94 and PG81, so I guess they would be similar if not the same inside. The circuit is simple so I draw the schematic (not sure if my voltage measurings are the expected). The capsule diameter is 15mm. The transformer seems to be around 3:1 (160r/60r and 82mH/28mH). My sample does not have the original foam behind the capsule.
In the pcb there is space for R3 that goes from R2/C3 to ground, maybe used in other microphones.
The gain is low but also the noise. Tried to use a jumper over R2 but haven't rised the gain much, maybe any other side effect of that jumper on the FR?
    476.5 KB
    703.8 KB
    500.7 KB
    389.9 KB
    405.7 KB
    190.1 KB
    126.8 KB
    69.4 KB
