Hi!
I'm working on modding a Shure M67 microphone mixer and had a quick question up potentially upping the voltage in the first stage of the unit. Schematic here: https://pubs.shure.com/guide/M67/en-US.
I'm doing the mod that has been pretty well documented (https://messageboard.tapeop.com/view...&highlight=m67) where you take some or all of the channels out of the mix bus and run them to direct outs before the summing stage.
My question is : could increasing the voltage of that first stage improve headroom, THD, noise and possibly squeeze out a few extra db of gain without consequences? I've been able to try it a little with a JLM T Rex power supply. It seems to work well if I remove the line bringing 34v volt to the board. If I leave that in there is feedback in the channel that is still in the mix bus. Is this because of the section in the summing stage that is 13.4v being increased and messing with the next stage? Or something else? I've been hesitant to increase it past 20v since there are some 25v caps in those sections and wanted to ask about this here first before swapping those and pursuing this any further.
Thanks in advance!
Thanks in advance!
