Shure SM58 XLR insert - 5 pin version?
It needs to go into a microphone, so needs that screw which is the only thing that keeps it securely in place.
It doesn't really need the wing.
switchcraft makes those.
Years ago in another life time, I had a tube mic on my bench that the complaint was it was intermittent. Well sure enough it was and the reason was a real head scratcher. 7 pin xls coming out of the mic, and I am missing 6 pins on that connector. I can only speculate that the person handling the mic tried to do a twist and pin and managed to break 6 pins. But that is just a guess, I never found out how it happen. I just had the aftermath on my bench. Anyway, Switchcraft sells inserts like that. They also sell full blown XLR's where you can take the insert out and be left with a shell. Depending on what you need, buying the XLR and removing the insert VS just buying the insert may be more cost effective.
Ah, so the switchcraft inline XLR insert will fit into an SM58 etc?
I believe that is the solution.
Thanks, we don't really do that much Switchcraft in the UK.
Just for interest, this is to convert a Shure 55 with a switch, so that via a breakout box, the switch operates the talkback switch on the desk remotely.
So the guy can lay on the couch at the back of the control room, directing the talent.
You might wanna check out Cliff UK's portfolio - get a much-cheaper-than-Switchcraft panel-mount make XLR and scavenge the insert itself.
https://www.cliffuk.co.uk/products/xlr/metal.htm
FC6175 or FC6176
