At the risk of being way off topic for this forum, here goes...
I'm installing some relay boards and trying to control them with a Siemens LOGO which is a small plc.
The relay boards have 12 relays that are tied to each other over a common V+ (24V).
Now, I bought a LOGO with transistor outputs (24V) ...
transistor output LOGO
With my previous cabling I had relayoutputs on my logo and I basically used them to open a path to ground.
Now, I don't see the way I can use these transistoroutputs to switch my relays ?
They don't switch to ground, even if they're on digital zero, they're not connected to ground.
thanks, ward
thanks, ward
