Siemens U273b
ToniTonmann
Member
Berlin
Hello,
does anyone know the U273b comp tuchel connector, who could help me with the pin allocation  ? I found a  schematic at
http://audio.kubarth.com/rundfunk/getfile.cgi?f=%3E%2C34Q%2C3DX%2CC%24R-E%5DU%2BW-I96UE%3BG-%3F%3D3%28W%2CV%28N%3C%261F%0A
but i'm technically an amateur and don't understand all of it (ok, i'm completely lost actually  ::) :eek: ).
There are two outputs - i guess i should use the +6 dB ? But which pins are hot/ground ? Also the 24V : "1" is ground and "13" is + ? The same for the input: pins 4-6, but which is which ?
Is this the right counterpart ?
http://www.akzent-audio.de/vintage-gebrauchtgeraete/steckverbinder/polzahl/13polig/145-amphenol-tuchel-13-pol-steckerleiste-t2706-fuer-siemens-w295/-emt-etc-gebraucht
Any help would be highly appreciated ! Thank you!
..you can't deep-link directly to Kubi.
The connector you show is a male, most probably the one you already have in the unit. You probably want the matching connector (but check for yourself first - these are getting expensive lately)
Jakob E.
Try to search for "Tuchel Amphenol T 2707". This should be the connector you need. There is one on German ebay right now for 20€.
I'm no expert either but I would connect it as follows:
PSU 24+ -> 13
PSU 0V -> 2
audio input hot -> 4
audio input cold -> 5
audio input shield -> 6 (?)
audio output hot -> 11
audio output cold -> 12
audio output shield -> 1
and connect 1 and 2 at one point together with the chassis you're putting the unit in.
But maybe wait till someone more knowledgeable can confirm this as I'm not quite sure about the input shield...
thank you Murdock ! This sounds like a starting point, unless someone has an objection. There's no hurry right now, so'll wait a couple more days.
https://www.ebay.de/itm/Tuchel-13-pin-Connector-T2707-f-Siemens-W295-W295b-EMT-256-258-260-u-a/322920322978?hash=item4b2f8d17a2:g:1mUAAOSwsYpaJED7
