That was in reply to your post about measurements on the LM358Spencerleehorton said:HI Ian,
DC bias?
DC bias?
I am using the 1073_1084 User Guide as found here
http://www.thehistoryofrecording.com/Manuals/Neve/1073_1084_User_Manual_Issue_5_1.pdf
Spencerleehorton said:Yes that is the schematic that I’m using.
Just out for xmas dinner will send P level once I’m back.
Spencerleehorton said:Hi Ian,
signal level @ P on 283 = 2.96 vpp
Spencerleehorton said:Yes there does seem to be movement with all pots, if i move frequency down to about 250hz the LF pot works, although CCW rather than CW and the HF works CCW if i then up the frequency to about 3khz.
when i select the frequency with the lorlin, pos 1 off, pos 2 to pos 5 the waveform gets smaller?
Is it meant to do this?
also to get anything to work i had to reattach gnd lead to 39k/12k resistor and now output is down to 2.48vpp
no inverter amp connected at this point and only scope on output of b205
