Simple low current voltage doubling circuit needed
Potato Cakes
Nashville, TN
Hello, everyone,
I am in need of a low current (less than 10mA) DC-DC voltage doubling circuit with SMD parts to fit in a very small PCB footprint. I started out doing research to make my own but most everything I have found involves AC-DC. The small number of examples that I found which are actually DC-DC involve a MOSFET device that switches between capacitors in series, but no guidance on what voltage to feed the gate to create the switching effect. I do not have the time to figure this out and I also despise dealing with power in audio circuits which has become the biggest headache when trying to complete projects. Requirements for the circuit are as follows:
- Input voltage: 45-50VDC
- Input current: less than 10mA
- Output voltage: 90-100VDC
- Output current: 4-10mA
- Fewest parts possible for stable output voltage
- Circuit has to be tested and known to work as required
The last part is especially important. I do not have time to test and verify. A schematic with complete BOM including alternative part numbers is to be delivered upon payment.
Paul
Well, let's start with just getting voltage to double. The I think the current is actually less than 4mA. If someone is interested in taking this on please let me know.
It should run on phantom power.
Phantom power supply as available on a mic preamp input? I.e. through the 6.8k resistors? If so, mission impossible as @gyraf hinted to in post #3. If powered directly from the P48 supply, then reconsidder the amount of current available to the circuit to ease the circuit design.
And how much ripple is allowed on the output?
Jan
Hello, everyone,
Paul
10mA output at 100V is 1W of power. The maximum power you can pull from 48V phantom is around 170mW @ 24V
so a perfect (lossless) switcher will only get you around 1.7 mA @ 100V, actually less.
Well, let's start with doubling the voltage even thought the output maybe slightly less than 1.7mA. I'm looking to see if someone who has power supply skills can take on this project and to give me a price. If it doesn't work in this particular instance then I can use if for other applications where the source current is higher.
Alternative part numbers to what part numbers ? Do you mean you require a choice of components that can be substituted / used interchangeably ?
Do you have a ball park budget or maximum in mind. Quite a job if you require prototype build and test results.
Doubling which voltage? The 48V is fed through 6.8k resistors, so as soon as you pull any current the voltage is no longer 48V.
If you double the realistic voltage you can get, you will be doubling around 24V to get 48V output. Is that what you want, or do you actually want to quadruple the voltage?
Or to state it a different way, do you actually want to double the voltage, or do you actually want 96V output? Because those two are not the same thing due to your misunderstanding of how phantom power works.
The idea behind an alternative part number is to be able to find components in case of components being out of stock. This mostly pertains to semiconductors. I can find different capacitors and resistors on my own if need be.
Further discussions regarding things like budget should be done via PM. I am trying to find someone who could take on this job and details should be discussed and amended between myself and potential hires.
Paul
Since a well executed design will never deliver more than 1.7mA @ 100V is that enough current?
To extract peak power from Phantom power you need to load down the two 6.81k resistors to 24V. Then you need to step up that 24V intermediate supply voltage up to 100V, not with a voltage doubler but a dc to dc switching "boost" convertor.
For only modest current output perhaps look at "charge pump" technology.
How well defined is your application... Is 1.7mA (or less) @ 100V really enough?
