[quote author="capnspoony"]yes sorry it is 6db and it is the winding ration I was talking about.
what do you mean by gain = 4x? just four times the amount? Or does that x hold some value?[/quote]
No, I'm talking about 4 times. For voltages, db gain = 20 x log (Vout / Vin). The log of 4 is about 0.6; 20 x 0.6 = 12dB. So a gain of 4x = +12dB.
To wire an opamp with unity gain I simply have a wire from the output to the minus inpur, correct?
Only for a non-inverting stage. Non-inverting stages have a gain of (Rfeedback / Rinput) +1. Rfeedback is the resistor from the - terminal to the output; Rinput is the resistor from the - terminal to ground. So if, for example, Rinput is 2.5k and Rfeedback is 7.5k, gain is (7.5 / 2.5) + 1, or 3 + 1, or 4. Which is 12dB, as described above.
For an inverting stage, the math is different. There, the gain is equal to -1 x (Rfeedback / Rinput), where Rinput is now the resistor going from the input to the - terminal. So if Rinput and Rfeedback are both 10k, gain is -1 x (10k / 10k) = -1. The - sign means the signal's polarity is inverted.
So if you put a non-inverting amplifier after your passive network and feed its output to pin 2 on your XLR output jack and also to the input of an inverting amplifier, whose output goes to pin 3 on your XLR output jack, you'll get an output signal on pin 2 which is 12dB greater than the input to that opamp, and a signal of equal level but opposite polarity on pin 3. The double signal (balanced) is the equivalent of 6dB additional gain, so your total is 18dB of makeup gain, which is what you need.
I'm not familiar with input bias current... Im just reaching my first birthday of DIY.
That explanation takes longer; I suggest finding a copy of Walter Jung's
IC Op Amp Cookbook. It's out of print, I think, but a lot of public libraries have it.
Peace,
Paul
