Simple onboard guitar preamp
CJ
GDIY Supporter
California
after trying a million stomp boxes ,
nice to have one cord and easy access,
9 volt battery in the cavity,
crazy thing is the 0.01 cap on the output, thought it would kill tone but this thing sounds better than any of the stomp boxes i tried,
thanks to Gus for the 30K idea,
Is there a specific reason for that 30k gate stopper? Does it oscillate without it? Just curious.
On the J201's I've tested, most were clustered around -0.9V VGS(off) and IDSS of about 0.6mA. With those values, center bias with the drain at 4.5V comes out to a drain resistor of about 27k and a source resistor of 2.7k. Given the diode's it looks more like an overdrive, so maybe ideal values don't matter. 🍻
The 30K rolls off high frequency gain into the Miller capacitance of the JFET.
Yes it is right in between a clean boost and light distortion box, the diodes are there as a limiter but turned out to add a nice compression to the boost,
Look at the bright input on a Hiwatt , 500pf is the coupling ,sounds shrill unless your hitting it with a vintage humbucker ,doesnt work with single coils at all .
Bright input generally works better with humbuckers , normal input with single coils to give back a bit of fattness .
