plumsolly
I was looking at the schematic for the control room monitor module in my console and it seems like it has a whole lot of stuff in there for just switching between line level sources and controlling volume (it does other things, just not things that I use for the most part). And in addition to all of that junk the signal has to pass through, in order to monitor from my converters or other sources, I have to plug them into line amps in my console - so more opamps and faders. So I was thinking about a simple passive monitor switcher/attenuator that I could mount in my console, like this:
I wasn't sure what to use for the attenuator. The input impedance of my powered monitors is listed as 20k, the output my DA is not published and the output of my console is specd at 65 ohms actual, 600 ohms nominal load, and acceptable range of 600 ohms or higher. So I guess I want the input impedance of the attenuator to be 15k or so, and the output to be 600 ohms or so. Does that sound right? I could order a stereo balanced bridged T attenuator in that configuration from shallco, but i have a feeling it would cost an arm and a leg, so i don't know what I'll do. Any suggestions would be greatly appreciated. The other question i had was in regards to clicks and pops - what should i expect and will it be tolerable? Thanks so much - Ben
