I came across the single order state variable filter on Rod Elliott’s site. It’s implemented in his bass amp as a unity gain crossover. I have a parametric EQ application for it that would require variable Q and static gain from both outputs. I could accommodate that gain being not 1, as long as both outputs were the same distance from 1. Here’s the basic circuit, with my best shot at a Q adjust.
I made the frequency variable with a linear pot. I’ve seen a rev log specified in Q adjust circuits that tie inverting and non-inverting inputs of the mix amp to ground, and Rqmax is often placed between the wiper and ground.
Rod describes R1 = R2 = R3 = R4, as the mix amp in normal non-inverting 3-amp SVFs is typically described - except typically R4 is positive feedback from bandpass and R1 is negative feedback from lowpass. This is different, so I’m wondering:
1) If the network to the left would do the variable Q job without changing gain over the RVq travel
2) If a variable resistance from the R3/R4 junction to ground would do the same, albeit only raising the Q
3) If R1 = R4 = R, and R2 = R3 = 2R, is the gain at both outputs still unity, but the Q (without an adjust) has changed
4) If you invert the LP output and sum it with the HP output, is the result a regular notch
FWIW the low shelf button on the Calrec PQ1549 turns a typical 3-amp SVF into the functional equivalent of this circuit, albeit with fixed Q and negative input. I assume the designer chose this method over simply grabbing the LP output because the result is a first-order response. Screencap is @gyraf ‘s redraw.
