Ha, that's exactly how I have found broken PCBs. I've found that capacitor is completely broken physically in the ones I've played with.
Send an email to Senn.... request schematic for PCB. I was lucky enough they just sent me a replacement at no cost. I'm sure once word gets out about this they may not be so apt to shoot off filter boards for free, but worth a shot.
Very gently push down on the center dome of the diaphragm. What you need to watch for is good movement, or bounce all around the coil. If the coil appears to go down/up concentric with the rest of the diaphragm then the diaphragm most likely is going to function.
You might try hitting the voice coil leads with a very small DC ~.5-1.5VDC. The diaphragm will jump up or suck down. If it sucks down, swap the polarity of your DC leads. Once you get the diaphragm to jump up, look around the edge for any air leak. If it doesn't get a good bounce, or jump up, you might try to re-flow the solder at the terminals where the voice coil leads terminate. After this if it still doesn't bounce well, it most likely needs a new coil/diaphragm assembly. If you can get Senn to send/sale you one let me know so I can stop reversing this design.
That dent very well may be putting stress on the flutes causing the excursion to not be optimal. What you can try, doesn't always work, is take some masking or other adhesive tape that will not leave residue, and roll it up like you're going to use to put up a poster. Now pinch it to get an adhesive point, now take this point and carefully press on your dent. Use the adhesive with a pulling action to try to pull the dent out. You might also try the blue tacky poster sticky stuff if tape won't grab it.
Do be careful, I've found that the flute area of these diaphragms is almost paper like and very very soft/fragile.
I'd also try to hit the coil leads with a low level signal from a sine generator. The element should act like a speaker and reproduce the signal. If no tone, something is wrong. If you get tone take the frequency generated to ~30Hz. You can observe the diaphragm bounce at full excursion up and down and note for any sticking or rubbing. Even as low as 10Hz will allow for the diaphragm to bounce very slowly, enough to observe the movement very well.
