Marik
Jonte Knif said:If and when I start with 10u spacing I don't have to mess too much before I have to lap the surfaces again to keep things in alignment. This might be the biggest problem affecting the accuracy of a series of measurements in my plan.
I really would like to have reliable method for measuring the diaphragm resonance before screwing it to the capsule. The impedance method sounds quite good, but then I have to build an acoustically transparent backplate for that job only. Worth the trouble I guess.
I'll keep you posted, for sure. From this point on it will take some time to get results.
The first capsule will be assembled in a couple of weeks or so. I hope it is not a total disaster.
Well, unless you are incredibly lucky and all the stars got crossed, most likely it might be... not a disaster, but something to start with. Just think that if you get at least some sound, then life is already good. You might find that the sound will be wheather too shrill, or way too mellow. Depending on the one you will just need to get little by little to go the other direction.
The 10um look little thin, but again, the final result will be the fine balance between capsule tension and diaphrang damping, which depends on the amount of air cution (i.e. spacing) and backplate drilling. With that spacing you might find that you will need to put much less bias on the capsule, and/or will be able put much more tension on the diaphragm. On the other hand, if you'd like to go Al (which I also tried), you cannot go way too much with the tension, because of the material fragility.
So all depends on the compromises you are willing to take. There are way too many variables to give you something more specific.
Best, M
