As I think I mentioned earlier start-up is a bit of a trapeze act. but it works at least for the original application.
To make start up a little more reliable, and the pre-regualtor more efficient I would try substituting a mosfet for T2 so the pull-up resistor could be increased. to reduce the current. "and" drop a 5V zener to ground in place of the emitter connection of T1 to the VR output. This should make it independent of load on the regulator. To keep the pre-regulation knee sharp you might want to add a pull up resistor to the 5V zener to keep it turned on.
Dumping the base drive current into the 5V rail was just to recapture that current into the 5V load. Making that current less with a mosfet makes capturing it less important too.
Or you could just use a switcher.. ;D ;D
