There is a method whereby you can make a self-powered ramping soft-start circuit (takes up to 20 or so secs if desired) with one transistor, but the circuit I know of can only handle an amp or so. Let me know if this is helpful and I?ll try and contact my friend for the schematic (he uses it on commercial units, is quite safe).
The second method would involve taking a bridge rectifier, 2 caps (size determines lag) and a relay. The circuit is mains powered. The circuit I have on my power-amps takes around a second for the relay to click, you?ll obviously have to use Ohm?s law for your app. In my amps there are large current-limiting resistors supplying a ?primer? current to the mains transformer, and then the relay clicks providing full mains current. You could adapt this circuit, leaving out the series resistors, and put the audio-out through the relay, but you may have to implement extra decoupling for the relay supply as it?s a raw supply?? (Anyone comment? If reservoir caps are large that should provide enough decoupling?). There may still possibly be a dc-offset so the second method may not cure all???
If you only need an amp or so I can see if I can ask my friend for the 1 transistor circuit, or maybe a whiz ?round here can rustle up something? :wink:
Justin
