SMPS TVS Diode continuity
Murdock
Germany
I have a problem with a SMPS. In my console (Acousta DCA100E) there are two power supplies working in tandem. So when one fails the other is still there as a backup.
I recapped one of them about two month ago with the aim to also recapp the other one soon. Everything worked fine until now.
It started with a high pitch noise coming from the module itself and a non working 5v rail. The high pitch noise would only occur a few seconds after power on and would start like a sweep and then run continuously at a certain frequency.
When I poked around with a wooden chopstick to find out where exactly the noise was coming from I thought to have found the noise source either at the resettable fuse or TVS Diode right next to it as the noise changed. But while touching the two components both main fuses on the transformer board tripped. There is no chance that the two components touched each other or anything else so I don't know what lead to the short.
But I realized that the TVS Diode now had continuity in both directions.
Here is a schematic of the SMPS. Can anybody tell me, what could lead to a shorted TVS Diode or overvoltage?
It's the D13 MPTE5 Diode on the 5V rail.
I know there are bidirectional TVS Diodes but this one is not.
As I understand the purpose of TVS Diodes is to go short when there is to much voltage and to trip the fuse before anything else happens. Is that right?
There is a rail going from the 5V rail just before the fuse and diode to a PWM. Could it be, that this one went bad?
I can not really find burnt spots on the board or anything else suspicious.
Could the fact, that one supply was recapped and the other not be a culprit?
Knowing that newer caps are more efficient than older ones?
Nevermind. I think I found the culprit.
One bottom to top vias for 63VGND did not have good contact and the IRFP250 FET2 is shot...
Will fix these and see if that's it.
According to Vishay they often fail to short:
Vishay doc on TVS failure
The problem with repairing switchers is everything is interconnected, it is hard to disconnect parts of the circuit and make sure just part is OK, so difficult to tell whether FET2 failed and that caused a problem with the 5V TVS, or the 5V TVS failed, and that caused too much strain and caused FET2 to fail.
The TVS should just be to catch short over-voltage transients, so you should be able to run without it, although probably best to disconnect the load (or connect a dummy resistor load) in case it failed because there was a sustained overvoltage failure.
