living sounds
Here's the schematic of a cheap transformerless mic:
I changed some caps two years or so ago (and didn't always know what I was doing), but this is what the components are:
C1 100n
C2 100n
C3 100n
C4 100n
C5 100u
C6 220u
C7 220u
C8 33p
C9 8.2p
C10 1n
C11 22n
C12 22n
C13 1n
C14 1n
C15 1n
R1, R2 22R
R3, R4 150k
R8, R9 1G
If more reistor values are needed I'll unsolder them, currently I cannot determine the values because the resistors look symmetrical, so there are always two possible values.
L1 150uH
L2 62uH
T1, T2 2N5401
T3 2SK170
T4 2N5551
All diodes are zeners.
I also did all the obvious mods (and may have also substituted bigger caps where it's not advisable). With all the mods (including grill and capsule) this mic now sounds very good, albeit pretty bright (but the C37 is a bright capsule, too).
Now I compared the schematics to the Schoeps one (in an excellent modding article by board member Rossi) and realized that C1, C2 form a low pass filter. Getting rid of those caps predicatably improved the high end response.
But I've still got some questions:
1. What is the purpose of C14, C15 here? From my very limited understanding these would result in some phase shift, but for what purpose? I took them out of the mic and couldn't find any difference. They're not in the Schoeps circuits, I think.
2. How high would be the polarisation voltage at the capsule? Is this a common circuit with predictable outcome (from the schematics)?
3. Would upgrading any caps besides C13, C3, C4 make an audible difference? What about C6?
4. Is there an uncomplicated way to balance out the high end vs. the low end a little? The low pass at the output takes away too much 16k and too little 6k, so to speak.
5. Would substituting T1, T2 with matched BC556 make a difference?
6. Any other suggested changes? Any mic previously discussed that matches the schematics
Thanks to anyone taking the time!
C1 100n
C2 100n
C3 100n
C4 100n
C5 100u
C6 220u
C7 220u
C8 33p
C9 8.2p
C10 1n
C11 22n
C12 22n
C13 1n
C14 1n
C15 1n
R1, R2 22R
R3, R4 150k
R8, R9 1G
L1 150uH
L2 62uH
T1, T2 2N5401
T3 2SK170
T4 2N5551
