John Hardy
- Joined
- Jun 4, 2004
- Messages
- 98
Deane Jensen's 990 schematic from his original 990 paper from mid 1979 included the output isolator. It also is shown in the slicked-up version of that paper that was published in the AES Journal in 1980. My 990 data package includes the output isolator in the 990 schematic. The text includes the following:
R15 and L3 (?output isolator?) are not part of the basic op-amp ?triangle? and are not included in the 990. They are available separately and are recommended in many applications for best results. See the Jensen engineering report for details.
There simply wasn't room for the output isolator in the 1.125" x 1.125" x .600" package that I use (API-2520 compatible), and isolation components are not normally included in an op-amp anyway. My schematic shows 1% resistor values instead of the 5% values that Deane specified, and a PN4250A transistor (Q10) is used in place of the original 1N914B diode (CR3 in the Jensen schematic).
My 990 data package is available at:
http://www.johnhardyco.com/pdf/990.pdf
The Deane Jensen AES paper "JE-990 Discrete Operational Amplifier" can be downloaded for a fee from the AES, or you can get a printed copy from Jensen Transformers or me just for the asking.
John Hardy
The John Hardy Co.
www.johnhardyco.com
John Hardy
The John Hardy Co.
www.johnhardyco.com
