NewYorkDave
Steve, feedback isn't a dirty word around here. This ain't an "audiophile" message board. :green:
PRR, I really doubt that CJ will ever get a chance to lay his dread hacksaw on a McIntosh output. Those transformers are worth a mint (and weigh about as much, too).
In the Mac output transformer, the two primary windings (cathode and plate) are wound bifilar, same number of turns. The primaries and the secondaries are interleaved several times. Two 5.5-pound grain-oriented steel "C" cores enclose the coils in a shell. There's a feedback winding of a few turns, but I'm not sure if it's wound bifilar with the secondary or separately.
Distributing the load between cathodes and plates allows a lower turns ratio, about half that used in conventional push-pull plate output circuits. As an example, a conventional amp using two 6L6s would use a plate-to-plate load impedance of 4K to 6K. The McIntosh used two 1K primary windings, bifilar. The winding technique reduced leakage inductance between the primaries to almost nothing, gave unity coupling, and the lower turns ratio reduced shunt capacitance. The interleaving of primaries and secondaries makes for tight coupling, high efficiency and extended frequency response. I think Steve has already made reference to the role of capacitive coupling between primary and secondary in the extension of high frequency response.
Such a transformer would be digustingly expensive to produce today; it was probably pretty expensive to produce even back then.
