NewYorkDave
You want to know the correct way to test a transformer for various parameters, or JUST how to test DC resistance of the windings?
If you do use an ohmmeter to check DCR, you may need to degauss the core afterwards. This can be done by injecting a low frequency signal, slowly increasing the amplitude until the transformer saturates, then slowly decreasing the amplitude back down to zero. If your ohmmeter has manual ranging, select the highest resistance range (lowest current).
A better way to check the winding resistance would probably be to do an AC impedance measurement, but at a very low frequency, below the audio band. The result would be higher than the true DC resistance, but probably not by much.
