Soliloqueen's k87(k67) and k47 capsules
Gotcha. I thought there were B-stock of the three pattern variants. I will just need to order more of those.
I decided to buy another round of parts to build a second pair of mics.
Paul
You can use them in three pattern mics, the figure eight will just not be perfectly mathematically even
they're under cardioid/omni
Ari, I apologize too!
I was also getting confused.
I am not a native English speaker, I use an online translator. In my native language "under" is translated "below", "one paragraph below" so it was understood that there are three categories:
Normal
Cardioid/Omni
B-stock
But there were only 2 choices.
Now I understand.
Thank you very much!
    595.5 KB
Normal
Cardioid/Omni
B-stock
Now I understand.
sorry but is your tab counter smiling
Disregard this post if this was already brought up - i admit to not reading the entire 100+pages.
If you sell B-Stock at a reduced price (wich i love!) think about marking them, to prevent them beeing sold years later down the line as "perfect" and people complaining. As you have serial numbers on your capsules maybe a small online tool for people to look the number up, as with "sell-date" and "b or a stock"
just my 2cp.
Hi Everyone, this is my first post here after lurking from time to time in the past. I just received 2 matched flat k47 capsules from Ari, and they are beautiful. I bought 2 turnstile audio tac1100 mics to put these in, and I replaced the capsule in one of them. However, I’m only getting figure 8. Cardioid and Omni are very very faint.
The capsule that is in the mic originally has a wire on the front and back diaphragm, as well as one wire on the ring on the backside, so from pictures I have seen it is a 67 or 87 style capsule? I soldered the k47 wires to the same spots to which they were connected previously, but something isn’t right. I am 99.99999999% sure that this is user error; I don’t think the capsule is the issue from everything I’ve read about Ari’s quality control and from the email interactions that we had.
I’ve done a lot of searching to see if there is any general info on this issue, but nothing comes up except something I remember reading about “then you’d wind up with a figure 8 only mic,” however I can’t find where that was written again. Is there something easy that I should check for? I can post pictures if that will help.
I am not an electronics genius (obviously) but I can solder and troubleshoot. One project I did years ago was the royer MXL tube mic mod. I originally had a weak sound from it, and David Royer answered my phone call and he let me know that I had the older instructions with the newer circuit board, so I had soldered the ground to a mounting hole. When I soldered it to the correct place (opposite the instructions!) it was glorious. So, I’m hoping there is something simple like that in this case.
For the record, the figure 8 compared to the other mic with the stock capsule’s figure 8 is so much better. So much better as in not even close- much fuller sound without the pinched top end of the stock capsule. Not that the stock capsule sounds bad, it just sounds typical of the inexpensive Chinese factory mics.
Thanks so much in advance for your help. I’m going to try wires in different spots to see what happens, but any insights are welcomed. These are the turnstile mics, and they appear to be built very solidly.
https://www.adorama.com/tac1100.html
Welcome! Post some good resolution pictures of the inside of the microphone.
Possibly in a new thread so as not to pollute this one.
Yes, figure 8 is working. I started a new thread with my troubleshooting questions as suggested so I don't derail this one, but thank you for checking in Ari!
more than a few people have complained that the k47v is too dark at the lower end of its tolerance range. Honestly, I'm not a huge fan of bright k47s, but after I refined the k47f i feel sort of like there is too much overlap, so i think i am going to redesign the k47v to be more like a vintage k47 (up 2-3dB at 4k instead of 1.25-2dB as they are now) so that there isn't so much overlap. this is still comfortably less than the 5dB of most chinese k47s, but definitely brighter. in some of the units i do hear it. one of the downsides of switching manufacturers is that our new plates will be way more precise, so the capsules won't have a wide spread of tunings. i won't be able to pick bright capsules or dark capsules for people who prefer each like i could before. you get what you get, and i have to decide what people get now. sometimes having tighter manufacturing is not actually better... i might make the k47v bright and keep the m7 dark, even though they could just as easily be tuned the other way around, as that's more what people expect.
(Cue Raymond Scott's "Powerhouse.")
No but legitimately this is what it was like watching my machinist program the new CNC code for the plates. It's such a small shop and he has real adult jobs to do that aren't humor me, so he had no choice but to automate as much as possible. At this point almost the entire plate is constructed start to finish by CNC, even the center plastic tap insertion. It's like watching a Looney Tunes assembly line where everything is done by big white gloves on sticks
Hi @soliloqueen !
I have sometimes wondered if through the long, intense, challenging and demanding journey towards a K87 as close as possible to the historical original, among hundreds of prototypes, you made, intentionally or accidentally, a capsule let's call it 'K87flat' which mounted in a linear, flat circuit, without deemphasis and in a correct headbasket/body, etc., to reproduce the frequency response (perhaps the behavior in general) of a U87i microphone or U87ai correct.
Yes, 3U does something similar, maybe others too, but in my ears not faithful enough.
So, in short, my question would be: Will there be a capsule like the one described above? ' Arienne K87F '
Thank you!
